wheel offset for 9.5 wide rear
Hello
I am looking to get some wheels for my car and wondered if a 9.5 wide wheel with a 35mm offset will work or will it stick out some. Any insite on this setup. 19x9.5 rear and 19x8.5 front, both with 35mm offsets.
Thanks for any help guys and gals.
Jonathan
Jonathan
I'm running a 9.5 rear +40 offset with a 30mm spacer so that'd be an *effective offset of +10 and I've got another 10mm to go I'd say. I guess it depends on your ride height and alignment specs. If my car were stock height I'd probablly be poking all over the place. What size tires you plan to run plays a part too. My 1/4s are shaved.
19's and headlamps lenses cleaned
35 offset 8.5 front 9.5 rear, but the fronts just barely come out past the fender, shouldn't be a problem when I lower it though
