strange noises
strange noises
I'll try to explain best I can...
So my 2gs300 started making squeaking noises in the front driver side wheel well. The noise was so slight that I couldn't pin point the issue. This noise would only occur when slightly turning to the left(about 1/8 of a rotation to the left of the steering wheel) and when bringing back to center slowly. It wouldn't make the noise when turning quickly. Now it's when I'm braking to a stop or accelerating as well. I inspected the suspension components and they all look fine. Any ideas?
Did you go under there yet?
I'm getting the creak as well, pretty sure its my upper control arm. Been too lazy to check. You need to get under there and reproduce the sound and find its location. If it rained recently and a boot is torn, the rain probably cleaned out all the grease and its now dry in there.
Get a look before this happens!
Hard to diagnose over the internet. Next easy half *** shortcut thing to do is grab a can of WD40 and squirt each moving part one by one as the steering wheel is turned. Have him/her create the sound, spray some in the upper ball joint and keep twisting the wheel for another 10-20 seconds (giving the grease some time to find its way into the joint) then move on to the lower joint etc... If the sound goes away, then it will be that last part you sprayed and you'll know what to change, I dont like that way, but its the best way I can describe over the internet other than taking it in to get looked at. Its really not that hard though...
Another thing (better idea than the WD40), get a hold of a short hose (like 20" long or so) put it to your ear and place the other end to each joint and ANY where else under there while the wheel is being turned, its just a matter of finding where the sound it loudest.
and no, that broken piece (level sensor) doesnt cause noise.
zaputnam
Suspension and Brakes
09-08-14 12:44 PM
phesa
04-14-11 05:42 AM
Gennady7
09-04-08 05:49 PM
