Heat blows hot only on passenger side
I am having the same issue as other older posts I have read, I only get heat from passenger side, even the middle center vent blows hot on the right center, and cold on the one to the left center... super frustrated. I followed all the suggestions, I took the glove box off and i can physically see all 3 servos working the one on drivers side works too.. what the heck can this be????? I am cold on drivers side... help
My coolant is fine and my temp reads half way at normal.. even when i adjust the temp to cold the drivers side gets more cold not much but you can feel a change but raise the temp to 85 and it still blows cold on drivers side and 85 on passengers side... it is not any servo's
It’s the same symptom in my 2016 car but it’s not repeatable. It happens mostly when it rains outside. Three time this embarrassing situation has happened. And I am not able to convince the dealership since it doesn’t happen it front of them. The technician basically called me stupid the last time I took it there with the complaint and she said I didn’t have the temperature set low enough on the dash and hence it kept blowing hot air. How do I convince them? I have warranty on my car.
Aron9000
SC- 1st Gen (1992-2000)
17
06-13-15 12:10 PM
sailorpam
GS - 1st Gen (1993-1997)
02-14-14 07:04 PM
