Difficult Decision
I need advice on my 2nd gen Gs3 my ride has 231k at the moment. I may need to replace the tensioner and thinking of replacing many more things like the timing belt or should i put in a newer 2jz in it. I keeping it for the long run. What would you do?
Why put in things that is not needed unless it's related to what you are doing?
If it's a timing belt tensioner, I say do the timing belt.
If it's the drive belt tensioner, replace the drive belt.
Well i want to do the timing belt as well as the drive belt and i need to replace the tensioner. I basically want to get the most out of 2jz life wise
My drive belt tensioner went out at 200k, you can fix that for under $50 and get a new belt and do that at the same time, I wouldn't worry about the timing belt unless you don't know when it was changed or you do know and it's been over 90k ago.
That's a hell of a difference in cost!! If you are just going to keep it stock, I'd go with the timing belt/tensioner replacement (if needed). If you are planning to go for more HP, then I'd buy a used 2JZ short block and build up a turbo setup and then drop that in once ready.
mooseboy84
10-31-15 11:35 PM
rx7guy
04-29-09 12:27 PM
