Instument cluster dark
Looks like the cathodes are burning out. Do a search on "CCFL" or "cold cathodes". Its easier to just replace the whole cluster. Some have replaced the cathodes with LED's (which create some hot spots) IIRC, you cant buy replacements for the stock lighting.
When you have the dimmer switch all the way up, are the rest of the lights in the car bright while the cluster is dim, or is the rest of the lights dim as well? Could be a bad dimmer switch if everything else is dim.
Hi, Tanin Auto here! What year is your GS?
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
DomRebel
GS - 1st Gen (1993-1997)
02-17-13 01:59 PM
bmsc300
SC- 1st Gen (1992-2000)
03-30-11 05:26 PM
