Please help my car won't start
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
It just cranks has spark and fuel and new battery and timing is only 50k old good starter relay
I'm thinking it's a crank sensor
Link below please help
What's the history of this car? How long have you had it? Did it do this before/after the Lexus dealer service? You'll have to provide some more context. Modifications? Have you altered something on the car? New parts? No reason for a car with good ignition/timing/fuel to not start. Have you looked at the possibility of the crank sensor?
I've had it one year the previous owner had maintenance done at the dealership
no mods except for blast pipes and Cai
No problems except the starter went out I replaced it
There was a self cranking issue disconnected the battery for like 2 days and it started doing this
I looked in to the Crank sensor I ruled it out because it's getting spark
There was a check engine for o2 sensor and that's it
The codes reset because the battery is out of the car
I did have a slight dripping from the windshield seal on the driver's side but it did get to anything only leak so it's not water damage
True on parts failing but I've never heard of a timing belt going out in 50k miles
Nothing extra anything where in the car and there's no way the timing belt will be good one day and the next it's bad
I'm thinking electrical like ecu or something
Maybe water got in somewhere
How old is the battery, coz my car was doing the same thing 3 days ago. Would crank but wouldn't turn on, tried to gas it when it almost started but nothing. Then the other day it started took it to autozone, asked them to check my batterie and the alternater. Turns out I had a bad battery , bought a new one and the car is starting up right away.
