Starter Replacement Problem (98 GS400)
Old 01-31-16, 04:18 PM
AfroMan623
AfroMan623's Avatar
Exclamation Starter Replacement Problem (98 GS400)
I decided to replace my starter this weekend since I was getting the one click syndrome and it was getting worse and worse.
The teardown was a beast, but i got it in ok. I used every every piece of advice i saw on this board about mounting the starter.
I cleaned the mating surfaces to a brilliant shine.
I supported the starter a bit so it would be straight.
I tightened the bolts, tapped the starter with a mallet, tightened again.
When i finish putting everything back together and go to start it, i get a terrible zip noise which I assume means the starter isn't seated properly.
I tried tightening the 2 mounting bolts, but it does the same thing.
Are there any people out there who were able to correct this? Is there anything I can do to fix this without having to take the whole ****ing engine apart again?
Thanks for any help in advance.
AfroMan623
02-09-16 10:41 AM
kyle98GS
12-18-07 08:26 PM
miko400
Maintenance
08-01-04 07:28 AM
Quick Reply: Starter Replacement Problem (98 GS400)
