Electronic seats moving position and self ajustable sterring wheel
Hi guys
I have a problem with my electrical seat position switches as when I start to move them it is like it looses power and I can't move the seat any more in any direction then I will have to wait for a few minute tell it starts to work Again I have all so got a problem with the seat memory buttons and my steering wheel self adjustment has a mind of its own works some days and others just wont move at all need help ..... rhd gs300
First of all. You have to see if your steering wheel is well lubricated and that way you avoid a lot of headaches. If that's not your problem, it is the motor that is go to damaged more and more every day or the computer can not take the position that you want to manage. That computer is located near to the steering wheel, under the dash. Put grease on the mechanism first to see what happens. I know is a thread for that. Check under diy thread. Regarding to the seat, if the back section of your seat works well? Your Prolema is the engine that moves the seat back and forward. Also, the switch on the seat probably the contact going bad. Also, those seat have a memorie computer. Do all the troubleshooting before change the computer and good luck.
Have you got the location of the computer and I think I need a bit of lubrication on the motor as it makes like a gear grinding sound when it is ajusting
