Help replacing a tail light
01 GS430 rear tail lamp was out so I replaced it. Then I noticed there is another light closer to the edge of the assembly that is out. Does anyone know which bulb or part number that is?
Mateo01,
What up? Check this webside.
http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
I hope this help you.
Hello-
The bulb for one of the small roundish tail lights on my 1999 GS300 is out. I'm not sure what "light" this is called on the Sylvania or other websites. Is it the "tail light bulb", "brake light bulb", "parking light bulb", "back up light bulb"????
If you know what bulb number is used that would be great.
Thanks,
Okii
Thanks,
Okii
7443, I believe. The 7443 is the running and brake lights.
The reverse is a 7443 and the turns are 7440.
AFAIK, you can use white 7443 bulbs for all the spots in the back of a 99 as long as it is the factory housing.
It is almost like that with an 01-05. The punks at Toyota changed the reverse light to a dimmer 924.
