No engine power to wheels after replacing alternator
10th Gear
I just installed a 200amp high output alternator I bought off eBay from a seller called PowerMaxUSA.
The car starts up fine and everything looks good until I put it in drive. Engine is not getting power to the wheels. No torque to pull the car forward. It slowly rolls as I press on the gas but pretty much gutless. Car is a 2001 Lexus GS430. Any ideas?
System is charging properly. No battery light or any other warning lights on the dash. No weird noises. Belt is not slipping, from what I can tell. Headlights don't dim when I try to go forward. I have not installed my aftermarket stereo yet or "big 3" upgraded cables. Everything else on the car is stock.
The original stock alternator just died at 120kmi, so I don't have a spare to put back in and test it.
10th Gear
Thanks for the tip! Hopefully I have time to check it out tonight after work.
That sounds totally logical. I pulled the alternator out from the bottom and pushed a bunch of lines around to wiggle it out. I didn't even think of that but it makes sense. Engine feels fine, but it behaves like driving a manual without letting the clutch out.
10th Gear
That's correct. Engine rpm's increase, but car barely moves. Car still has some torque to go in reverse, but not much to move forward.
What do you mean by a "5th jolt"? Does that just mean step on the gas in reverse?
10th Gear
Jeez, I guess I can't read. Thanks for the correction/clarification. I'll check out the transmission oil level, check for leaks, check for kinked lines and try get it to make a jolt backwards and let you know what happens.
Yea, just step on it
No dont go WOT, but just give it, well a jolt
Its an old dealer trick, IIRC, no one knows why it works, it just does
I think it just re-cycles the fluid. and yes, check the fluid level. I had a similar problem.
LOOOOOONG story (short), when I got my car painted, they cut my transmission line while trying to remove my alternator (again, its a long story LoL Like, what does an alternator have to do with a paint job right
) anyways. The lines were cut and I would lose fluid constantly, even after many failed repair attempts. Finally after succeeding the repair, no problems. But up till that point I would frequently have the problem you're having, scared the shat out of me! But yup, just threw it in reverse, gave it a jolt backwards and the car was back on the road until the next time the fluid diminishing reoccurred.
10th Gear
Car is working fine now. I really appreciate all the help - THANKS!
I couldn't find any bends, kinks, or leaks in the transmission lines. Fluid level was good. I gave the car a small jolt in reverse, then it was fine. Go figure.
tklovett63
Build Threads
11-10-14 12:36 PM
