shaking rack sound?
Old 03-10-16, 06:13 PM
OGgs300
OGgs300's Avatar
Default shaking rack sound?
So my gs300 has been making this weird shaking rack noise (if that makes anysense) when i go over any bumps. Its queit when on smooth streets but if the roads is bumpy then it make the noise. I also notice that it doesnt make the noise as im pushing on the brakes. I have plans to change out the rear brakes n rotors so i was hopeing maybe ill find the problem then but i was also hopeing some one could give me maybe an idea of what it could be.
Old 03-10-16, 06:37 PM
firelizard
firelizard's Avatar
Probably swaybar end links. Or blown struts. But start with the simplest. Check your balljoints and bushings while you're down there.
Old 03-11-16, 10:50 AM
OGgs300
OGgs300's Avatar
Dont think its the struts. Those where replaced recently
Old 03-11-16, 12:55 PM
RXGS
RXGS's Avatar
For me it was swaybar bushings. I had initially ruled them out as I had replaced them a year prior with polyurathane ones, but after buying a new pair the car didn't sound like the suspension was going to fall out of it anymore
Old 03-11-16, 03:49 PM
OGgs300
OGgs300's Avatar
Okay ill keep that in mind, and the way you said that sounds exactly how my cars sounds.
Old 03-11-16, 03:55 PM
bruceb58
bruceb58's Avatar
Another reason I would never put poly bushings on my car.
Old 03-12-16, 12:15 AM
firelizard
firelizard's Avatar
Yeah, I did Daizen and they lasted about a year.
Old 05-06-16, 09:02 AM
OGgs300
OGgs300's Avatar
So i figured out the problem. I just switched out my rear rotors brake pads and the parking brake. Killed all shaking rattling noise. So happy it wasnt anything else or serious. Thank you guys tho for tour help and opions!!
Old 06-10-16, 12:24 AM
OGgs300
OGgs300's Avatar
Out with the old
In with the new<br/>
undrcroft
RX - 1st Gen (1999-2003)
11-22-16 11:11 AM
vostro1
Suspension and Brakes
04-16-15 08:25 PM
LexiGS4ty
26
01-14-13 01:59 PM
808is3
CL of Hawaii
21
11-14-12 03:41 PM
schmoozer
01-05-10 10:42 AM
Quick Reply: shaking rack sound?
