Steering wheel tilts intermittently
Just passed 217,000 miles on my '99 GS4 and my tilt/telescopic wheel moves in and out fine, but sometimes won't move up or down. All I get is a single click. Eventually if I hit the switch enough it will move albeit very slowly. I've seen a couple threads about taking it apart and spraying some lithium grease in the mechanism and see if that works. Anyone else had something similar happen?
Do what Mcon said. There is a write-up on how to do it. You need to clean the old grease out and clean the metal contacts and it will work as new. Mine only does it when it gets cold. Im in Socal and it dosent get that cold so its occasional, but still bugs me.
We have beat this topic/issue into the ground. There is a very detailed write up about it.
So I took the cover off and greased any visible areas, specifically the screw that adjusts the tilt (see pic). This didn't seem to help much. Any areas I am missing?
In the 'Sticky' section above the current posts, there is a big list of FAQs and DIYs.
https://www.clublexus.com/forums/gs-...pic-wheel.html
