Air is not blowing!!
Old 04-12-16, 09:40 AM
msh34646
msh34646's Avatar
Default Air is not blowing!!
I have a 98 Lexus gs300. It has roughly 180,000 miles on it.
Problem:
- when the A/C or Heat is turned on, there is no air blowing out.
- everything shows as if it is preparing to blow out and nothing happens.
What I know:
- that i can hear the servos working as i crank the heat up or lower the temp for colder air.
Can anyone help me with this problem?
Old 04-12-16, 10:09 AM
Mr Jokster
Mr Jokster's Avatar
Hello, welcome to Club Lexus
Sorry to hear about your problems. First thing that comes to mind is somethings going on with the blower. Before saying it may be a bad motor, I say check and replace the relay.
Refer to this thread for some steps to take, good luck:
https://www.clublexus.com/forums/gs-...or-99-gs4.html
Old 04-12-16, 10:18 AM
Mr Jokster
Mr Jokster's Avatar
Heres the location and part number for that relay:
Old 04-12-16, 10:23 AM
Mr Jokster
Mr Jokster's Avatar
And heres the location of the blower and the assembly part numbers (if its something that you need to get into)
Old 04-12-16, 08:18 PM
msh34646
msh34646's Avatar
Thanks for all the information. I forgot to say that i did replace the relay first.. I guess i may be the blower motor..
Old 04-13-16, 03:56 PM
MikeFig82
MikeFig82's Avatar
You may have a bad blower resistor. Have you taken out the blower motor and ran it to 12V direct to see if works?
You can try to add a chassis ground to the blower wire itself. The ground wire tap into it and ground it to the chassis. If you blower comes on full blast it confirms the resistor is bad. You won't be able to control the fan speed setting though.
Old 04-13-16, 08:30 PM
Mcon
Mcon's Avatar
Just in case is the the control blower motor. Check this link.
https://www.clublexus.com/forums/gs-...igh-speed.html
IownaGS300
12-18-14 07:06 PM
morocca
09-26-14 07:38 AM
MJA1951
06-28-14 07:48 AM
salimshah
RX - 1st Gen (1999-2003)
10-29-11 03:54 PM
VIPNiSS
09-21-09 09:42 AM
Quick Reply: Air is not blowing!!
