Transmission Slipping?
Anyone else notice that when its cold if you give gas and then take your foot of the brake the car doesnt want to keep coasting? This happens for maybe 1/2 a block at most and then the car seems perfectly normal. Also started noticing some slipping when its cold and car hasent heated up. Yes I have been extra careful and letting the car heat up now but still found these symptoms to be weird....anyone else have these issues?
Car only has 115k miles
The engine shifts slowly and tends to stay in 123 at low speeds. It helps the engine warm up quickly. It's not a failure or slippage but just a cold start program the engine/ tranny run
Thestroomi
04-12-16 12:52 PM
