Rollover valve replaced. Gas smell gone, P0441 P0446 still there
Old 04-26-16, 04:19 PM
akafixture
akafixture's Avatar
Default Rollover valve replaced. Gas smell gone, P0441 P0446 still there
I replaced my rollover /cutoff valve since I had a gas smell by the passenger rear door. Gas smell is gone, but the 2 codes are still there, P0441 and P0446. I got a new OEM gas cap just in case since its a cheap part. Still those 2 codes. What else should I replace/check, vacuum leaks, VCV?
From my searching some have said the VCV (vacuum control valve)
Not sure if this means anything, but most of my cars have a vaccum sound when releasing the gas gap at fill up. This car does not.
thoughts?
Old 04-26-16, 06:31 PM
Mr Jokster
Mr Jokster's Avatar
Usually its the purge valve on the charcoal canister. Pretty common...
dumb question.. you DID clear the code after the replacement right?
Old 04-26-16, 06:33 PM
Mr Jokster
Mr Jokster's Avatar
I had the 446 and 441 for a good 4 years, after I replaced it, the 446 went away. However, the 441 stayed. I found a vacuum hose popped off on the far back bottom by the fire wall due to the valve being closed and no where for it to vent...
Old 04-26-16, 11:07 PM
Mcon
Mcon's Avatar
Mr. Jokster,
Do you have any diagramm or pics of where is located this vcv, please.
Thanks in advance.
Old 04-27-16, 10:51 AM
LexusK
LexusK's Avatar
Check ALL your hoses under the hood and make sure they're not loose. P0446 code is usually the VCV that's at the rear of the car around the spare tire well and that part is $25 ish from rockauto.com. I had the same code and after doing research, bought the part and had it replaced for around $100 for the labor.
DORMAN 911602 **#9091012109, 9091012209, 9091012271}
http://www.rockauto.com/en/moreinfo....316113&jsn=354
And here's a coupon code for rockauto
4409039139738352
I have a 98 GS400.
Old 04-27-16, 11:29 AM
akafixture
akafixture's Avatar
Mr Jokester, yes codes were cleared. I have the software for my laptop to read and clear codes.
I will check the vacuum lines, purge valve and VCV and report back.
Old 04-27-16, 03:15 PM
Mcon
Mcon's Avatar
akafixture,
Old 04-28-16, 11:59 AM
akafixture
akafixture's Avatar
Mcon, in this image they have it listed as the VSV valve. Its located on the charcoal canister by the fuel tank.
Rollover valve replaced. Gas smell gone, P0441 P0446 still there-62217_emissions_system2002_1.jpg
Old 04-28-16, 03:20 PM
Mcon
Mcon's Avatar
Attachment 386229
akafixture,
Thanks for the information and pic. I have time tomorrow to check the all 3 sensor on the TB to see what can I see or found out
bryceis250
02-21-18 11:16 AM
GeorgeGS3
09-02-17 05:20 PM
Chefao
Performance & Maintenance
11-11-13 07:41 AM
black sc
12-15-01 03:03 AM
Quick Reply: Rollover valve replaced. Gas smell gone, P0441 P0446 still there
