Noobie here
Noobie here
hey guys, was looking at grabbing a 99 aristo and was wondering about some insight on it if you guys don't mind. Its a 99 aristo with the 2jz-gte vvti. has 168,000kms. I was told it needs cam seals and valve cover gasket(s). are the cam seals hard to do? thanks again for your input!!
Hi 992jz,
First, Welcome to the club and forum.
Second, is no that hard to do.
Third, Check this and you found out all the info that are you need.
https://www.clublexus.com/forums/gs-...iy-thread.html
Welcome! One of the best things you can do is replace the valve cover gaskets. My slow loss of oil practically disappeared. The other thing I did was the motor and transmission mounts. Do those and it will ride like a new car! At a stoplight I can barely tell the car is on now it's so smooth. Well worth it IMO.
2jzinsider
Performance & Maintenance
14
09-19-12 06:28 PM
