Rear window going down
Hi
All my windows are working fine, except one - rear left.
I can close it, open - this working, but when I use AUTO UP - window is going up, and then is going down and stopping in the middle.
I bought new MPX module but it didn't help. I took the MPX from the rear right door, but still not working.
What more can I check?
Thanks.
Thanks.
There might be something on the rail that the mpx is detecting as a restriction and is opening in the case its a finger. The other, the rail might be slightly loose and when it gets to the top it twists like a mm enough to trigger it. Try slightly pushing up with your hand while its going up all the way till it closes and see if it closes.
