Questions about front end Frame structure
Old 05-22-16, 02:02 PM
Aquarian47
Aquarian47's Avatar
Default Questions about front end Frame structure
alright this is only my 1st or 2nd time posting here ever, but I'll try to get straight to the point.
-01 GS300
-front end damage
trying to figure out which parts are bolt-on to the frame (such as core support and bumper reinforcement bar), and where the actual frame starts.
I am trying to see how badly the actual solid frame of the car is bent.
so far most of the bends I've found seem to be the bumper reinforcement bar, the 2 parts that that bar attaches to (name?), and the core support.
does anyone have a diagram of all of these connections? does the core support bolt directly onto the frame? can't exactly tell as I haven't removed the side panels yet and I'm still new-ish to the GS.
will post more pictures if requested but here's a basic front picture with the headlights and bumper removed.
I need to know if it's fixable without welding anything.
sad face
Old 05-22-16, 04:44 PM
Mr Jokster
Mr Jokster's Avatar
Old 05-22-16, 04:52 PM
Mr Jokster
Mr Jokster's Avatar
Old 05-22-16, 05:05 PM
firelizard
firelizard's Avatar
That's gonna need a frame pull. Take it to a shop that knows what they're doing.
Old 05-22-16, 09:40 PM
Aquarian47
Aquarian47's Avatar
any idea how much that might run me?
Old 05-23-16, 08:55 AM
Mr Jokster
Mr Jokster's Avatar
IIRC, about $250. But thats California here everything is double LoL
Old 05-23-16, 09:35 AM
sakataj
sakataj's Avatar
no way Nathaniel, a good frame pull from a shop will cost you a lot more $ than that.
also, OP junk her, you can find another GS for less than what your about to put in her IF she needs the frame straightened EVEN if you use junkyard parts for the other parts
what part of Tn you in OP?
Old 05-23-16, 12:26 PM
Mr Jokster
Mr Jokster's Avatar
Yes way...
and obviously it depends how bad it is. Maybe just like everything else... I've just got the hookup.
OP: its about $60-$100 an hour.
Old 05-23-16, 12:33 PM
sakataj
sakataj's Avatar
Yes way...
lol if you say so... when they did my Nissan 240sx it was close to $2k for it with not much more damage than he has, which is why they ended up totalling it and that car wasnt old (it was way before the 240 was a cool drift car)
Old 05-23-16, 12:36 PM
kevin3344
kevin3344's Avatar
Looks like a lot of work for a GS3. Why not take what you're going to spend on repairs and find a low(er) mileage GS4? You might have to do some searching, but I bet you could find one in the $5-6 range. If mine had that much damage that's what I would do.
Old 05-23-16, 08:48 PM
Aquarian47
Aquarian47's Avatar
to all: I spent $4000 on the gs3 but I do not have enough to get a decent replacement car. could incrementally fix but that's about it.
also, I'm from Nashville, TN to you^ that asked.
Old 05-24-16, 01:56 PM
sakataj
sakataj's Avatar
IMHO throw it away, get a estimate on it but i almost assure you it will cost close to that to fix and i would say half assed.
im in memphis so bout 3 hours from you
Old 05-25-16, 01:52 AM
Aquarian47
Aquarian47's Avatar
I highly doubt it would cost $4000 to have some frame work done....
Old 05-25-16, 08:01 AM
bruceb58
bruceb58's Avatar
It's going to be $4k minimum to get it back to normal with everything. That is why you shouldn't bother. Sell the parts and put it toward another car.
Old 05-25-16, 11:40 AM
sakataj
sakataj's Avatar
i never said $4k for frame work, i said more than $4k to fix. get a estimate and then throw this thing away
Quick Reply: Questions about front end Frame structure
