oil leak need help !
hello club lexus, i am trying to locate an oil leak in my motor. seems to be coming from the upper front portion of the left side and dripping down the front of the motor possibly coming from the valve cover, to the oil pan. however have been unsuccessful in finding a picture of someones gs400 with a leaky valve cover. have found many threads but none with pictures.
I don't have pics but that's exactly where mine was leaking. On mine I would see a dark liquid near the alternator / front side of the engine just below the valve cover. When I was stopped at a light you could see fumes coming up (which of course was the oil burning). I had them replaced around 180,000 miles. One thing is for sure you will notice a big difference once you have them replaced!
the most fresh oil thats came since i cleaned it last night was only a small drop. altho over the coarse of 3-4 months since my last oil change most of the oil had been lost.
hmmmm this used to have pics, i used it recently to replace my other valve cover gasket but on my work computer i dont see the pics now
https://www.clublexus.com/forums/gs-...ks-advice.html
I had one recently on my 02 GS430 that ended up being the double o-ring that goes between the block and the oil filter bracket Lexus Part No.: 15692-50020. Took a while to find it because it would only leak under pressure when driving and never left any garage marks.
I degreased the entire area, drove on the highway for a bit and checked it again. Appeared to be the only thing it could be.
Sure enough it was hard as a rock and split when I pulled it off.
Not saying that is your problem but it was on the front left side of the engine and took a while to find.
Good luck.
Good luck.
