PO171 & PO420 Codes
Old 05-26-16, 05:01 PM
Benny701
Benny701's Avatar
Default PO171 & PO420 Codes
Hey,
I have a 2000 GS400 with 227k mi. Recently, my CEL has been going on and off. I've checked the codes before and after to see if they are the same. They are: PO420 Efficiency Below Threshold and PO171 System too Lean (Bank 1).
I cleaned the MAF sensor, changed both air filters, and the throttle looked fine.
Here's the interesting part; since I've owned it (2nd gen), the fuel level indicator will not drop past 1/8 of a tank without her running out of gas.
I'm considering trying to drop a sparkplug and see if it burns off leftover fuel that's been sitting and check for leaks but, I wanted to ask if anyone thinks differently. Eg replace the O2 sensor first or have experience in knowing it's definitely the cat.
Anything would be helpful. Thanks!
Old 05-29-16, 02:24 PM
BCP43002
BCP43002's Avatar
For P0420 look at:
Gas leakage on exhaust system
Heated oxygen sensor
 Three-way catalytic converter
for P0171:
Air induction system
 Injector blockage
 Mass air flow meter
 Engine coolant temp. sensor
 Fuel pressure
 Open short in heated oxygen sensor (bank 1, 2 sensor 1)
circuit
 Heated oxygen sensor (bank 1, 2 sensor 1)
ECM
Old 05-30-16, 07:48 AM
kevin3344
kevin3344's Avatar
When mine ran out of gas with 1/4 tank it was the fuel pressure. I would have that checked and see if it helps.
https://www.clublexus.com/forums/gs-...ml#post9484003
Btw, I have a '99 GS4 with 218k.
Old 06-28-16, 08:26 AM
Benny701
Benny701's Avatar
Thank you very much both of you! Keeping this amazing car up can be frustrating because it's solid but, becoming expensive. Upper and lower ball joints "failed" the other day -front driver- and, now, my mechanic (who's the best I've had yet) said the diff was leaking, front sway bar wear and tear, NAPA gave me the wrong caliper after another mechanic did a shotty job on a refurbished pin but did correct the problem (very thankful they stepped up), and ABS sensor is out for the count after the ball joints broke. I'm nearing my wits end. Trust me, I wish I could just take it in and have it taken care of with the best parts because it's the best vehicle I've ever drove.
Old 06-28-16, 12:35 PM
MattGS300
MattGS300's Avatar
Got the same codes - turned out it was a dirty injector in the #1 cylinder. A few tanks of premium with injector cleaner and all is right with the world again.
Old 06-28-16, 12:58 PM
Benny701
Benny701's Avatar
I did try that...a couple times, to say the least. CEL always, eventually, came back on with same codes. Still working on it.
Old 06-28-16, 05:33 PM
kevin3344
kevin3344's Avatar
Hang in there. It can be frustrating when you have a lot of repairs at once, but these cars are worth it! Definitely get the fuel pressure test when you get the chance. The dealer can do it (expensive) or if you have a good indy. Most of the time when it stalls with 1/8-1/4 tank that points to the fuel pump. Let us know what you find out.
Old 08-23-16, 09:56 AM
tiguy99
tiguy99's Avatar
In for any updates!
Hayk
20
07-01-12 10:14 PM
brabbit
RX - 1st Gen (1999-2003)
42
04-17-11 11:15 AM
zombie
16
04-26-07 07:01 PM
hksimpson
11-07-06 05:46 PM
dallison
02-07-06 06:40 PM
Quick Reply: PO171 & PO420 Codes
