Premium Fuel
LS430 owner, acquiring a '02 GS300 w/ 85k for my son. I'm sure the question of premium fuel v. register has been over-discussed on this forum (as it has on the LS430 forum). That said, I will pose it. Since the kid will be buying his own gas, what do you think about using regular? Thanks.
2. "the kid will be buying his own gas"?? Before this who bought your Gas? Mom?
3. If you have to ask.. Then the Answer is "Gas is Gas"
Apparently the ecu will compensate for putting crap in the engine (doesnt make it ok imo) However, a word for pops... Teach your son that its not worth dirtying the engine to save $3 on a FULL tank of gas
People rarely put a full tank of gas, so he's only saving a buck every time he puts gas in. Teach him the extra dollar is worth keeping the car in best condition ![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
Also, everyone needs to learn that top tier gas DOES have its qualities. Sure, gas is gas, but every companies additives is what makes the difference. On that note, I've learned that 2jz LOVES Chevron gas and I've found that although you spend a bit more, you get much more mpg than other gas so it comes out to be cheaper (never did the math on exact) but its significant. Thats only compared to 76 which too is a to tier fuel source.
IIRC, the higher the compression, the higher the octane you need for the reason of the above statement. but the computer does a good job at regulating the fuel to air ratio, thus my statement that the computer will compensate for the lower octane gas. Saying that the lower octane gas is caca (as i always do) relates only to how the car reacts to the improper fuel.
I say, stick with what the car suggests and that will eliminate the occurrence of knock which will also eliminate the possibility of engine damage/failure.
You actually will get better MPG and power with premium vs regular in a car designed for premium and that adjusts the timing less advanced when pinging occurs with regular.
Putting premium in a car designed for regular however will not increase power.
daryll40
07-21-20 07:19 PM
stevelifts
06-05-17 09:44 PM
