i need help
so i cleaned my steering wheel telescope and tilt motors. i put it back together and i notice a little spark when i put the steering column up to bolt it (weird right?)
so now the power windows dont work.
climate control doesnt work,
abs and brake indicator lights on the dash are on.
car doesnt shift out of park without the bypass switch.
brake switch good
the fuses i thought could be related are good.
any ideas on a fuse are relay that relates to this?
i googled and someone said that a door fuse was the culprit. i checked all those fuses, theyre good.
i do have an aftermarket alarm. i'll try and reset that tomorrow
brake switch good
Aamirsc400
07-05-15 09:22 AM
