Gs 400 fuel pump fix
Old 06-09-16, 04:21 PM
jadedgs400
jadedgs400's Avatar
Default Gs 400 fuel pump fix
Hi everyone, I just wanted to share a little info on fuel pumps for the 2g models. I have a 2000 gs 400 and it died on me on my way to work the other day, got it towed back to my house and assumed it was a fuel pump, checked for spark , and it had spark on all cylinders. So next step remove back seats and check the fuel pump resistance. Turns out the pump showed on my meter 20 megaohms, so I figured the motor was bad. Keep in mind I measured the resistance of the bottom pins, the ones going to the fuel pump. I took the fuel pump out and removed it from the module I guess you could call aka giant hunk of plastic . as I took the motor out I wanted to check the resistance again just to be safe. Checked it again and it was 2.0 ohms. I didn't even clean the connectors or anything before I checked it again. So I put 12v to the pump for about 2 seconds and it spun right up. The problem here was a dirty connector.. Maybe even loose, just wanted to give some info. wish I had taken some pics.
Old 06-10-16, 05:45 PM
badblackgs
badblackgs's Avatar
Now thats a good post. informative, proper grammar, and the issue was resolved. Nice.
Silgs300
10-15-17 06:38 AM
SCgonecray
Performance & Maintenance
08-20-12 09:20 AM
epicaudio
09-01-10 07:18 PM
blaznsc4
03-28-05 12:17 PM
Quick Reply: Gs 400 fuel pump fix
