LED Tail Light Problems
I have a 99 GS300 with clear LEDs in the rear. For some reason . . . All of the lights work even both turn signals, but when pressing on brake, the driver side one doesn't get brighter. All of them get bright except that one. What could be causing this issue?
Use a meter or a test light to measure the output from the harness and see if there is any power coming from it. If there is power then the LED may have a short inside. If no power then its your wiring. Best of luck
