Win Spoiler install question
For those with the Win spoiler, did you just use adhesive for the install? Or did you actually drill into the trunk lid (and spoiler) to make sure? For those using adhesive, any problems?
Thanks.
Thanks.
Mr. Anderson....
I had my spoiler attached with both adhesive and bolts. Extra precaution in case someone decides to rip it off...I have heard that it happened before with lip-style spoilers...
Brent
Brent
Speaking of using tape to keep things on (sorry to tangent), how do ya'll with the L-Sportline Roof Spoiler keep it on without being afraid of it being ripped off by someone?
-Anthony
I believe all roof spoilers use Adhesive only... The genuine WIN racing rear spoiler was originally supposed to use adhesive only as well. I would have it bolted on for good measure.
Originally posted by Neo
That means drilling into the trunk and spoiler.
The true WIN spoiler is only attached by adhesive. As long as you are comfortable with that, then it should be no problem. The one I have is a WIN-style spoiler and came with bolts attached to the spoiler. I just had the body shop replace my factory spoiler with the WIN-style spoiler and I believe they had to drill one set of extra holes.
Brent
Just wanted to see that since I may have to drill, are there any advantages to getting the original, other than I know I have the original vs. the replica? Once I drill, wouldn't the original be the same or similar to the replica? If so, I would also have the option of doing adhesive only on the replica, right?
My UGO roof spoiler is going to be adhesive only anyway. I wanted to get both spoilers on at the same time if possible. My UGO is waiting for my decision with the trunk spoiler.
Thanks for the responses so far guys.
Are there any differences, visual or otherwise, between the Win-style and the original (other than the bolt holes)? I currently have no spoiler. I'd have to drill into the trunk lid. That said, can the replica be attached with adhesive like the original? Meaning is the contact surface any different?
The reason I went with the replica was because:
1) Availability.
2) It came with bolts so you have to drill holes.
3) It's cheaper than the true WIN spoiler.
The true WIN spoiler does not have attached bolts so you will just be using adhesive. It all boils down to whether you want to bolt the spoiler on or adhere it. The replica looks just like the true WIN spoiler except that it's made of fiberglass. I don't know if the true WIN kit is made of fiberglass as well...Hope this helps.
Brent
Originally posted by bravo261
brent, i'm sorry, but can you elaborate a bit why protruding?
I am EXTREMELY sorry! I got it wrong. I just remembered that my WIN replica spoiler ONLY had bolt holes so you can indeed have the flexibility of adhering the the spoiler or bolting it. You basically bolt it from the inside of the trunklid, through the drilled holes on the trunklid, and screw the bolts into the bolt holes of the spoiler. I wish I had a pic but I don't...Sorry. The factory spoiler has the same configuration!
Sorry NEO!
Brent
As for losing the spoiler because of the adhesive, I am already taking a chance with the UGO and somewhat with my TTE front lip. There are a few screws in the front lip but it is mostly adhesive anyway.
Thanks for clearing this up Brent.
