2001 GS300 Radiator recommendations
Hey all so I started to notice that the top part of my radiator is starting to turn brown. My car currently has 87k miles and it being 15-16 years old it is probably a good idea to change out the radiator. I searched and only found threads that were from 2010 in regards to radiator recommendations.
The first was Denso:
does include radiator cap.
https://amzn.com/B0049GJK02
and the 2nd was Spectra:
does NOT include radiator cap.
https://www.rockauto.com/en/moreinfo...373835&jsn=314
both are similar in price so I was hoping to get some feedback from you guys on which to go with. My local mechanic has agreed to do the install for $110 which includes coolant and testing.
Do the radiator at the same time you replace your timing belt and water pump so you don't have to drain the cooling system twice.
You are basically due for your timing belt do do it at the same time.
I would just go with the denso since it is probably the OEM.
DENSO 221-3121 fits 98-05 Lexus GS300 $79.80 shipped
I just installed the above, and like another poster said, i did the timing belt, tensioner, waterpump and cam/crank seals all at the same time
bloomwcjkl
10-18-18 05:43 PM
wbmx1981
02-04-14 12:17 AM
