vsc, vsc off lights on - 02 GS430
Hey guys I changed my knock sensors and starter today and when I put everything together I accidentally broke to injector clips.
I went to the junkyard but could not find a junk GS430 to pull injector clips from so I found a late 90's Camry with injector clips
so I cut those off and soldered them on and connected everything back together. I started her up and she idles fine and then all of a sudden the "VSC" and "VSC off"
along with the CEL comes on. I drove down the street but it feels like it's not firing on all cylinders. Assuming everything was connected correctly, I am wondering if the Camry
injector clip wires are different resistance causing this. Can anyone chime in and give their thoughts and experience? Thanks in advanced. I did search before starting this thread.
Without the codes it's hard to tell. When my CEL+VSC+VSC off happened it was related to my throttle body sensor. They ended up replacing the whole unit eventually.
akafixture
02-13-20 05:28 PM
btanchors
03-27-15 09:28 AM
