Can a valet key be cut into a master?
From what I have read (YES I SEARCHED) the master keys have the grooves along the top edge and the valet keys don't. Is this the only physical difference, and would a locksmith be able to add those grooves?
I pushed my trunk valet button only to discover my key isn't cut as a master so now I'm locked out of my own trunk. It is, however, programmed as a master because the security light turns off the instant it goes into the ignition.
A new key is in the mail but I need to get into my trunk before then...
Pardon me but I guess I'm used to forums where people actually know how to solve problems instead of just rice out with body kits and lowering struts and flux capacitors and "hey just stick a ziptie in it." Actual mechanics and technicians seem to be the minority here. Yes, I do feel frustrated right now.
Apologies for coming off rude but when I come to a forum and ask a question it's not because I'm looking for a shortcut. I'm looking for information to solve the immediate problem at hand which will not only prove valuable to me but to the next person that will have the question.
BTW you friend Lexo98 has a solution for you.....in the old thread i would think this thread belongs in anyways
https://www.clublexus.com/forums/gs-...ml#post9585512
Tell you what, Sakataj. You can help me help myself, how does that sound? I'll send you every thread I found while searching that could have answered my questions if somebody had actually replied. You answer all those ignored threads, and then you'll not only help me, but also the person who asked the same question and got no reply because it was too difficult. Deal?
bye Felicia
Forum Administrator
Guys lets get this thread back on track and off the personal back and forth.
OP, I think you might want to ask your question to a locksmith. I suspect they are going to tell you know - freehand adding features to a key doesn't sound like anything I've ever heard or read about.
They (locksmith or dealer) either have a key template instruction based on your VIN to cut a master, or they are duplicating an existing key (which you don't have with the master grooves)
In theory it should be possible, if the inner "teeth" cuts are the same and the only physical difference is the edge grooves.
It'd take some careful comparison between an actual master and valet key before I would likely feel brave enough to attempt it. It would be quite valuable to know though.
Forum Administrator
Once you get your new master you should be able to compare more closely and measure with a micrometer to answer the question.
IMO there's too much precision work in order to make something like this viable... locks don't like even little variations. Doing the grooves by hand vs simply buying a key doesn't seem that great an option IMO unless someone is in your current situation with a valet that works like a master and is locked out of the trunk (very rare). I'd just buy a key that works and break into my trunk as above if I really needed to get into it before it arrived
TracyAnnFL
11-22-13 10:19 AM
