Thermostat gauge malfunction turning off a/c?
Old 08-28-16, 07:58 PM
ALEXGS99
ALEXGS99's Avatar
Default Thermostat gauge malfunction turning off a/c?
Has anyone heard of the ecm turning off the a/c when the thermostat gauge/ maybe sensor stops working?
Ive heard it does it to protect from over heating?
Old 08-29-16, 04:53 AM
burny
burny's Avatar
this is correct and there is a coolant temp sensor that fails and needs to be replaced. very easy to get to
Old 08-29-16, 06:31 AM
ALEXGS99
ALEXGS99's Avatar
thankyou very much and I'll take a look at that, do the sensors usually goo bad often? Or in my cause where it just turns of the temperature gauge? Ill see if can find it should be something on here
Old 08-29-16, 09:41 AM
Mr Jokster
Mr Jokster's Avatar
It not necessarily turning it off, its just not sending any information to display
Old 08-29-16, 10:15 AM
ALEXGS99
ALEXGS99's Avatar
The sensors is intermittently working at times]
Old 08-29-16, 10:21 AM
ALEXGS99
ALEXGS99's Avatar
The sensors is intermittently working at times. It's tricky. Any ideas on where the sensor is. Tryed doing research but can't get a definitive answer. I looked around the water pump and couldn't find any sensors.
Old 08-29-16, 03:17 PM
Mr Jokster
Mr Jokster's Avatar
CRuby
Performance & Maintenance
11-30-23 04:53 PM
JerryWatts
RX - 1st Gen (1999-2003)
12-21-17 09:51 AM
jimbo409
01-08-16 01:37 PM
VerbalKent
04-03-15 02:27 PM
HiPSI
SC- 1st Gen (1992-2000)
09-09-11 08:10 AM
Quick Reply: Thermostat gauge malfunction turning off a/c?
