Sc300 pedals in a gs300?
I'm looking to manual swap my gs300 and I noticed a lot of people use the is300 pedals but has anyone tried to use the sc300 pedals?
Sorry if this has already been asked I looked for a while and couldn't find anything
I am using the sc300 pedals as far as i know. I have access to an sc300 that im pulling the w58 tranny and pedals out of this wknd to fit into my 03 GS. Ive done the gte swap using the auto and found out after that the auto is not a good tranny for the swap becuz of the wiring. Not to mention, the auto wont hold more than 400 ft lbs trq. My motor is built for 600.
You can use any pedal you want from any car, because it's all custom. Nothing just fits, so just pick something and make it work. The ABS ecu is also directly mounted where the pedal needs to go. So you will need to move it out of the way, there is not much slack at all on the harness and it has a 105 wires going to it. I move them to behind the glove box which is 5ft of wire extending. Some people just cram the ecu over and zip tie up, but there is not much room and is a not a clean way to to do it. Make sure you remount the yaw sensor in the same orientation it is in once you remove it off the ecu as well.
