Car Shaking!!! VSC lights on !!!Help
Ok guys this morning on my way to work ......
The oil light turned on for a bit then went off...
Before getting on the freeway my Engine started shaking BAD like it was badly misfiring after that the
VSC and VSC off. Lights came on.......
HElp!!!!!
HElp!!!!!
When my VSC/VSC Off happened my throttle body went bad. The dealer tried replacing just the throttle body switch but that didn't fix the problem. They had to replace the entire throttle body assembly. Let us know what happens.
I notice that the idle is fine just the engine shakes at stop on acceleration or if I turn on the AC while stopped!!! Shaking seems to go away when at higher speed
gs3213
10-26-11 02:32 AM
