Tail Lights
Old 10-18-16, 05:40 PM
Jose562
Jose562's Avatar
Default Tail Lights
It says that the tail lights are out in the dash board but when we check they work could it be a senser ?
Old 10-18-16, 09:09 PM
lexo98
lexo98's Avatar
If you have aftermarket tail lights that's a common issue. The resistors suck. My light randomly comes on all the time
Old 10-19-16, 04:08 PM
Jose562
Jose562's Avatar
Default Tail lights
Is there a way to fix them
to remove the light indicator from the dash
Old 10-19-16, 04:26 PM
Mr Jokster
Mr Jokster's Avatar
You can remove the bulb or you can disconnect the wire that sends that signal.
In the trunk under the driver side fender carpet theres a module that you can remove the wire. Heres the module:
Remove or cut the purple wire with the red stripe:
Old 10-20-16, 04:16 PM
firelizard
firelizard's Avatar
Have you checked your third brake light? One of the bulbs in it being dead will trigger the light-out warning but the assembly in general will still function.
Old 11-13-16, 02:05 PM
AmanO
AmanO's Avatar
How do you release the pin? I jammed a tip cleaner down there but cannot get anything to release.
Old 11-13-16, 02:43 PM
mate01
mate01's Avatar
Don't assume that a bulb isnt out. Make sure you really check each bulb back there, I found out the hard way.
Old 11-17-16, 02:17 PM
AmanO
AmanO's Avatar
I have LED tails. That is why the dash indicator is getting triggered.
Old 11-19-16, 01:25 PM
1sWt2GS
1sWt2GS's Avatar
Another way is take the bulb out of the dash or black electrical tape to cover it
DON'T USE THE RESISTORS THAT RUN WITH THE AFTERMARKET TAIL LIGHTS.
They can become very hot and potentially dangerous.
Old 11-20-16, 09:19 AM
AmanO
AmanO's Avatar
Yea, I am going to take the resisters off when I get that light to go off.
I do not want to cut that wire, but I still cannot get the harness to let go of that pin.
Old 11-20-16, 02:53 PM
Mcon
Mcon's Avatar
AmanO,
You need a very small flat screwdriver to make sure fit inside the plastic plug inside the terminal. The wire terminal have a very small pin that keep it inside the plug. You need to separate or push that pin from the plastic plug and then pull the wire out.. Try that
Old 11-21-16, 11:30 AM
nelson09
nelson09's Avatar
Originally Posted by 1sWt2GS
Another way is take the bulb out of the dash.
thats what I did. 5 minutes tops, could do it in less now that I've been through it!
Old 11-22-16, 10:49 AM
LexusK
LexusK's Avatar
Just installed my new LED tails. I'll probably just pull the bulb since that seems easier than dealing with unscrewing the module and poking around in the trunk.
Lveyolfe
02-28-17 11:05 AM
Ted404
RX - 1st Gen (1999-2003)
12-02-14 05:46 PM
Redskns92
SC- 1st Gen (1992-2000)
04-10-06 02:48 PM
pudieinpa
12
08-14-05 04:43 PM
TypeSC300
07-05-01 06:56 AM
Quick Reply: Tail Lights
