Mystery Lean codes that no one has been able to solve. HALLLLP.
Hi all, so a quick run down, 2gs 2002 109k on the clock, p0174 and 171. ive had 3 transmissions installed at the dealer this year, and soon after the third one, (the only one that seems to be working properly) I started having a stumble off idle when throttle input was any more than feather foot. (I've been using SNOW mode to get around).
when this first started happening I took it to the dealer, thinking it may be trans related; they identified a hole under the heat shield of the factory style intake. so I built a quick one to hold over using ricer pipes and hose cheap spectre clamps. still getting the lean codes. then new MAF, still lean.
got new plug wires, a coil just incase because 2 and 5 were misfiring. repaired the harness to the ignition coils including new OE connectors. However, I noticed increased fuel consumption and increased fuel odor. If I stick my nose near injector number 6, kind of inbetween it the intake and the brake booster stuff I smell fuel. now, I've looked and felt around but I feel no wetness around there. traced the lines all the way to the tank but no liquid fuel. does any one have a good set of live data for me to compare to?
I've checked just about everything I can think of minus pulling the fuel pump. including soaking things in starting fluid to no avail.
Help me fix this and there will be a reward.
lexus won't touch it till I get it fixed.
Sears couldn't find it, literally told me I've done everything they could possibly do withing reason.
Sears!!!!!!!!???????????? Oh my. I highly recommend you find a qualified mechanic. not specifically knocking Sears techs. but I'd be surprised to see if any of them have an L1 Certified Master tech. on staff. plus one whos familiar with toyota lexus vehicles. have you checked fuel trims? smoke tested? checked fuel pressure? swapped 02 sensors? introduced secondary fuel to see if fuel trims change? usually a stumble on acceleration can be linked to a improperly adjusted tp sensor. especially since you've been thru three transmissions? who keeps putting all the transmissions in the car?
smoke tested, not really. starting fluid yes.
fuel pressure is on the list.
02 sensors on b1 both failed the min and max voltage tests.
a stripe of starting fluid on the cone filter settles the motor a little at idle.
sears, just didn't wanna get involved.
and Nalley Lexus has installed all 3 transmissions.
do you have a good base set of live data values for me to compare to?
tps was I think at 14.1 - 14.2 at idle. didn't pay attention to the curve. it's actually next on the list.
I've been without my volt meter.
look at the long term fuel trim. if the readings are high at idle and no mis fire likely you have a vacuum leak . you said P0171 and P0174 that means you vacuum leak could be by your air filter housing and throttle body hose intake system. air is by passing the maf. Something you may want to check the vent hose from your charcoal canister could be dumping gas into the intake system because of this the ecm is leaning the system .
