Can a bad battery or terminal issues cause door lock issues
Old 10-30-16, 08:23 AM
mwwilliams
mwwilliams's Avatar
Default Can a bad battery or terminal issues cause door lock issues
I have a 2003 GS300 that is now starting to not lock the driver side rear door when you use remote or the door lock button. You hear the click and then another click right after that. Locks all other doors but alarm not set. Then next time you try, it may work. Is it the actuator or the batttery?
Old 10-30-16, 09:17 AM
firelizard
firelizard's Avatar
Actuator. Very common issue. I'm down to 1 consistently functioning power door lock on my '02.
Old 10-30-16, 03:37 PM
nyc80rick
nyc80rick's Avatar
definitely sounds like a actuator
Old 10-31-16, 03:00 PM
AnneDye
AnneDye's Avatar
Default actuators
Anyone know the best way to replace it. Someone told me to live with it. Because it'll cost a lot to replace the actuators.
Old 10-31-16, 03:15 PM
bruceb58
bruceb58's Avatar
Just fix them:
https://www.clublexus.com/forums/gs-...rs-diy-30.html
Old 11-01-16, 10:18 PM
TW99GS300
TW99GS300's Avatar
Parts are like 20 each on ebay. if you want to save more, just buy the electric motors and the gear puller.
There's quite a few DIYs on here and even youtube videos showing you how to do it.
I replace them all the time so I get plenty of practice, can replace all 4 within 1.5 hours.
Read thru all the diy on these and just take your time.
Take pictures of things you take off so you remember how to put them back on.
Old 11-02-16, 10:53 PM
bruceb58
bruceb58's Avatar
Yes...for Chinese junk. I wouldn't waste my time putting those on my car. Replacing the electric motor is the most cost effective fix.
Old 11-03-16, 12:13 AM
TW99GS300
TW99GS300's Avatar
Where do you think those motors come from?
Old 11-03-16, 02:08 PM
bruceb58
bruceb58's Avatar
Mabuchi made in Japan!!!
Old 11-11-16, 05:08 PM
mwwilliams
mwwilliams's Avatar
My new battery fixed my issue. Back drivers side door now locking normally again.
Old 11-11-16, 05:13 PM
mate01
mate01's Avatar
nice mr williamths
Old 11-14-16, 01:53 AM
bruceb58
bruceb58's Avatar
When mine started failing, it would depend on the temperature until it would finally do it at all temperatures.
My bet is that it comes back. If your old battery was able to start your car, it wasn't the battery causing your lock issue.
Old 11-14-16, 10:53 PM
TW99GS300
TW99GS300's Avatar
FYI Japan doesn't produce much of anything anymore, vehicles gets final assembly there, but for the most part, things like a DC motor gets manufactured in China, Malaysia, Thailand or other South East Asia countries.
Old 11-15-16, 07:55 AM
bruceb58
bruceb58's Avatar
Mabuchhi does have factories in other countries although its largest factory is still in Japan as well as 5 other factories that are still in Japan. None are in China or Malaysia.
No matter what, I would still not buy those cheap $20 door actuators. My bet is that it does not even come with a Mabuchi motor in it. Penny wise...pound foolish.
Old 01-11-17, 11:52 AM
Samuelphsr
Samuelphsr's Avatar
Gentlemen, i just changed the actuators in my 2000 Gs300. The front door locks work fine but the back doors will not lock or unlock when I press the unlock on key fob. So I say to myself I can live with this by manually locking the rear locks. The front doors will lock when I set the alarm. But when I disarm the alarm the horn goes off and the key fob will not allow me to disarm it until I put the key in the ignition and turn it. The only way I can keep the horn from sounding when I open the door after setting the alarm is to open the trunk first then close it, then open the front door . Has anyone had this happen to them?
Quick Reply: Can a bad battery or terminal issues cause door lock issues
