LED Turn Signals
This is a much spoke of topic all over the internet... Search is your friend
Your solution? Buy an LED blinker relay and replace the factory blinker relay. ALL LED's are going to give you hyper flash because they run on 1v of power.
I stand corrected... I just searched (as we all should) you can buy LED's with built in load resisters, but they cost more.
Pun intended?
I have 2 pairs of switchbacks.
If I did not have the yellow cone in the front turns I would wire them up as DRLs. (I do not have any at the moment)
The rears are wired for turns and reverse.
http://www.ebay.com/itm/2x-T20-7440-42-SMD-2835-LED-Car-Dual-Color-Switchback-Turn-Signal-DRL-Light-12V-/331983373990?hash=item4d4bc046a6:g:jsIAAOSwCGVX6irX&vxp=mtr
Your correction was my question all along. Let me re phrase my question.
What are some good recommend brands of LED bulbs with built in load resistors I could purchase?
The only "brands" of LED auto lighting, that I know of are Philips and Sylvania. Everything else I have ever seen is rebadged Asian stuff.
I would be surprised if Sylvania's bulbs did not have load resistors int them.
Check these out.
https://www.amazon.com/SYLVANIA-ZEVO.../dp/B01CKQP9MK
I forgot to mention that mine have load resistors in them.
Check these out.
Check these out.
Awesome thanks for this.
http://www.vleds.com/all-products/v3-triton.html
LED Flasher:
http://www.vleds.com/all-products/flashers-modules.html
Pick your poison
Good quality LEDs with resistors]
Copied from: http://www.vleds.com/all-products/v3....html?___SID=U
They sure do if you buy as a package (else it wouldn't work at all)... Switchbacks are currently on backorder though.
I just picked up some Sylvania Zevo's and they are nice so far. Not a blue look to them, crystal white. I actually found them at a local auto parts store.
They still hyper-flash without a load resistor or LED relay.
