Snow is coming - Ballast
The snow is coming and I am concerned about my son (relatively new driver) in an '02 GS w/ 88k. The car came with an almost new set of Michelin X-Ice snow tires but I would like to be extra careful. Has anyone put extra weight (100 pounds of sand, rock salt, etc) in the trunk and had success in winter weather? Any winter driving suggestions are appreciated, thanks in advance.
I don't know how old you boy is, most important is to drive for the road condition. After wrecking two cars(Subaru WRX, Nissan Pathfinder) he is now very good driver driving BMW 3-series, nice little car. He still miss the Subaru AWD system. That MIchelin is good winter tires. Daughter never got into any accident by contrast.
All good points. He learned to drive in my LS430, rear wheel drive with snow tires so it should be similar. I taught him to use the the snow setting if the road has any ice or snow on it. A full tank of gas also adds weight in the right spot. That said, we will head to the nearest high school parking lot tomorrow for practice if we get the predicted 6 to 8 inches. 100 lbs of ballast in the trunk just behind the rear seat can't hurt. Thank you for your comments.
I haven't had the need to do that. The GS is not prone to fishtailing. In fact, because it tends to spin just one wheel, it's actually a little tricky to make the rear step out unless you are very reckless, or deliberately weight-transfer to induce oversteer. X-Ice are as good on ice as their name implies- they are a good choice for this car in winter.
Tires make a huge difference. I have **** tires on mine. Read end kicked out a few times even in rain. I am driving it like a grandpa in wet weather, too.
I cannot do **** in the snow. Today was the first time in it with my GS. Hopefully last time, too. I am so glad, now, I kept my Camry as a winter beater.
OP, you close to the Ohio line? We got at least 6 inches already and are scheduled for 7 more hours of snow.
In winter time traction. in summer time hydroplaning both are very important. I once witnessed a airborne car due to hydroplaning caused by wreckless high speed
driving. Cars contact to surface area is few square inches of rubber on 4 corners. I never cheap out on tires. Always I go for best sets for my driving style.
My 2002 without snow tires was brutal, especially getting it going from a redlight, stop sign etc. but with Michelin snow tires, it made it one of the best cars I've ever had in the snow. The weight will help, but you probably won't need it. I think the heavy weight helps because it helps the tires dig in. I found it best, especially around town, to keep the traction control off and in snow mode, but that was just me.
All our vehicles in the family are AWD(not all AWD system is created equal) type, have two sets of tires for summer, winter. Most scary surface is black ice. Also winter
rims are one size under to have tall tires(digs in better). I do seasonal tire/rim change myself including TPMS programming when needed. IMO, best AWD system is
that of Subaru.
that of Subaru.
I took the car through the snow this morning to get the ballast (2 - 50lb bags of ice melter). While the roads had been treated a little in the hour I was shopping, I could feel the difference on the way home. The rear end was more firmly planted and solid feeling on the way home. It may not be necessary but it can't hurt. The bags fit very well on the elevated portion just behind the back seat. With all of your help, we survived his short first winter driving experience. Thank-you.
Good point. I may switch the bags to sand. Alternatively, I may put them in a box or "double wrap" with thick trash bags. Ideally, I would like to find lead or similar bars. In any case, he drove through our first 8" snow fall without incident.
