Everything died...
Old 12-10-16, 08:00 PM
rorfan24
rorfan24's Avatar
Default Everything died...
Ok so I looked all over the internet but I couldn't find anybody who had even an remotely similar problem so here we go. I recently changed my 1998 gs400's battery. Before tightening the positive pole, I just dropped the battery mount on it to check if everything was find before I tight it in place (so it was loose on the battery). When I got in the car, the radio worked, gauges lighted up, etc so I turned the key farther to start it and then "click", everything shuted down. I tried to connect the battery to a fully charged booster pack without any luck. Now, the car is just completely dead. I probably toasted some kind of fuse somewhere or an ecu. Do you have any suggestion for me dear members?
Old 12-10-16, 10:53 PM
Mr Jokster
Mr Jokster's Avatar
I say check connections again. Check the wires and how they're attached to the terminals.
Old 12-11-16, 11:52 AM
kevin3344
kevin3344's Avatar
I just went through this, it was a loose battery terminal. If your accessories work that's probably what it is. If you don't get any lights/radio then I would dig a little deeper.
Old 12-11-16, 12:21 PM
rorfan24
rorfan24's Avatar
Yep that was it aha I just noticed that thank you!
Hiep25
ES - 5th Gen (2007-2012)
03-12-18 05:58 AM
Robertcave
05-31-14 08:05 AM
UR2klose
Performance & Maintenance
15
02-13-10 06:45 PM
mac187
GS - 1st Gen (1993-1997)
11-13-08 11:41 AM
Lexologist
03-23-05 09:29 AM
Quick Reply: Everything died...
