1998 GS400 Brake Booster Noise
Old 12-14-16, 01:36 PM
rfcbuf
rfcbuf's Avatar
Default 1998 GS400 Brake Booster Noise
My 1998 GS 400 (115,000 miles on vehicle) has a brake booster screech when applying brakes,especially when outside temp is cold. Screeching noise is usually quite short in duration and often goes away after driving for an extended time. I understand a new unit is quite expensive and is labor intensive to install. I'd like to know what options exist for repair. Also what would be expected if I just drive the car as is and wait until the pump fails to address the problem.
Old 12-14-16, 05:05 PM
Mr Jokster
Mr Jokster's Avatar
Been driving mine with that noise for like 5-6 years now. Now it happens all the time... Havent had a problem
hope that helps.
Old 12-15-16, 03:00 PM
rgarjr
rgarjr's Avatar
Yeah its expensive since they decided to cram everything in that one part. To replace it is not that hard however.
Old 12-17-16, 05:48 PM
Agent$mith
Agent$mith's Avatar
I'm actually on my 2nd BMC. You can go with a junkyard one 98-00 model or upgrade to the 01-05 in which they improved it, but you need to move over the oil pressure sensor. There is a sponsor named Aliga that you can message and get it from. I was able to get someone to rebuild mine.
Chilton88
Hybrid Technology
09-07-19 09:42 AM
rfcbuf
12-05-18 02:01 PM
rfcbuf
06-23-17 05:10 PM
gzhottt
04-27-13 09:18 PM
sternern
10-28-10 05:31 AM
Quick Reply: 1998 GS400 Brake Booster Noise
