Gs300 oily spark plugs
Old 12-17-16, 05:33 PM
Doneve79
Doneve79's Avatar
Default Gs300 oily spark plugs
Hey fam, it's been a while. Well, last week my 01 Gs300 threw multiple codes P0300, P0304, P0305, P0306, P0171, P0174 etc... so, today i removed the intake, coil packs & wires, then noticed all my plugs were soaked almost to the top. Funny things is...i dont see any oil leaks from the valve covers... so, were could it come from?
Thanks im advance for your suggestions & opinions.
Old 12-17-16, 05:47 PM
zippymbr
zippymbr's Avatar
The oil came from the valve cover gasket fail. The valve cover has seals around each spark plug hole. This is a common problem. The oil causes a misfire hence the codes you are getting. Buy a valve cover gasket kit, clean out the spark plug recess and coil boot and you should be good.
Old 12-17-16, 05:57 PM
Doneve79
Doneve79's Avatar
Im not too sure about the valve covers. I have no oil residue around the covers. Plus, the valve cover gasket set doesnt have rings for the plugs.
Here's the set:
Old 12-17-16, 06:44 PM
zippymbr
zippymbr's Avatar
Here's the set:
yes that set does not have the spark plug seals. This valve cover is strange and in 3 pieces. Those seals are for the cams. Look at Rock auto parts
Old 12-17-16, 06:46 PM
zippymbr
zippymbr's Avatar
Look for the ones listed with spark plug tube seals
Old 12-17-16, 06:48 PM
zippymbr
zippymbr's Avatar
Most of the oil seeps out of the side gaskets down into The trough
Old 12-18-16, 06:23 AM
Doneve79
Doneve79's Avatar
Okay, I'll look for the 3piece set. However, the 2001 GS300 comes w 2 separate valve covers, and there's a channel in bettween where the coils & wires goes. There's no way to remove the channel in order to install the spark plug seal.
Here's a pic from the sticky DIY section showing the valver & the plug channel in between:
Old 12-18-16, 12:22 PM
FrankT
FrankT's Avatar
No tube seals in a 2JZ motor.
Old 12-18-16, 03:29 PM
Doneve79
Doneve79's Avatar
thought so too
Old 12-19-16, 07:39 PM
zippymbr
zippymbr's Avatar
Oops my bad. I forgot which Lexus I was working on last. My wife has the GS
931UZFE
Performance & Maintenance
13
06-20-17 06:33 AM
NihS07
08-30-11 06:52 AM
xdubber
01-14-10 02:53 PM
smoothie18
03-23-09 06:54 PM
2muchpsi
12-01-07 07:47 PM
Quick Reply: Gs300 oily spark plugs
