Passenger airbag removable from dashboard?
Old 12-19-16, 07:48 AM
Finsun
Finsun's Avatar
Default Passenger airbag removable from dashboard?
I plan to replace my dashboard. The new dashboard doesn't come with the passenger airbag.
So when I remove my original dashboard, is the passenger airbag attached to it? Can I remove it and put it with the new dashboard?
Or is the passenger airbag attached to the car and the dash just covers it?
Old 12-19-16, 05:22 PM
Mr Jokster
Mr Jokster's Avatar
Its covered:
Old 12-20-16, 07:28 AM
Finsun
Finsun's Avatar
Ok, so if i take off the dash, I just disconnect the airbag connector and remove the dash with the airbag still in the car.
Would i have to disconnect the battery first before disconnecting the airbag connector or it doesn't matter?
Old 12-20-16, 09:00 AM
ksultan78
ksultan78's Avatar
yes. disconnect the battery whenever you are messing with your airbag.
Old 12-21-16, 08:30 AM
Finsun
Finsun's Avatar
I'm still a bit unclear. I plan to swap to a black dash.
Should I buy a dash that comes with an passenger airbag or one without (so I can reuse my own from my car)?
Old 12-26-16, 02:25 PM
kwalker705
kwalker705's Avatar
Can use one without and swap your current airbag over to the new dash. Couple nuts and a bit of securing rope are all that hold it inthe car
Old 02-06-17, 03:24 PM
malillie
malillie's Avatar
Default Passenger air removal from dashbord?
why are you replacing? Let the dealer. Keep it safe
Old 02-06-17, 03:31 PM
JamieS29
JamieS29's Avatar
Yes, it's removable and able to swap into a new dash since you are replacing the whole dash. We just parted out a GS, removed the air bag since the dash was damaged. The airbag is removable, just be super careful when taking it out, you will see it held in with a white string, looks like a shoelace. You'll understand once you tear into it.
Good luck, it's not fun replacing the dash!
ES330MD05
06-25-12 04:31 PM
Brencent
09-25-11 11:50 AM
owenxguo
09-27-10 11:25 AM
Quick Reply: Passenger airbag removable from dashboard?
