Real time help: Sound like a bad coolant temp sensor?
Old 12-19-16, 12:01 PM
eicca
eicca's Avatar
Default Real time help: Sound like a bad coolant temp sensor?
EDIT: Turns out I trusted the mechanics too much. Loose negative battery cable was making my transmission go funny and they didn't reconnect the fan switch on the bottom of the radiator, which made my car take FOREVER to warm up and sucked my gas tank dry only 13 miles after the light turned on. So that explained the stumbling, the fans, and the tranny, all in one quick easy fix.
So in the last few days, the transmission has been slipping at takeoff, the car started stumbling really bad when I cold started it yesterday morning, and five minutes ago, when I was about to leave for the dealer to get parts, I noticed that the radiator fans were firing up when I turned the key to ON. Didn't even start the engine.
Sound like a bad temp sensor to anyone else?
Old 12-20-16, 07:54 PM
Htony
Htony's Avatar
If temp. sensor is bad, you'd have a starting/idling problem. Isn't there a relay switch for fans? Also I suspect mechanic left the fan plug off.
alwabel
12-04-18 07:07 PM
SCB12345
11-03-15 06:44 AM
ivnnln
08-26-10 04:29 PM
desol11
Performance & Maintenance
05-30-08 12:39 PM
azari
12-21-03 10:03 AM
Quick Reply: Real time help: Sound like a bad coolant temp sensor?
