Spark plug wires ? How many ?
Old 01-04-17, 07:35 PM
eeric7
eeric7's Avatar
Default Spark plug wires ? How many ?
can someone please help me ,i have a 2002 gs300 I was told that I only need 3 spark plug wires ,but even though I require 6 spark plugs because 6 cylinder engine ,I was told I only need 3 wires because of something about how the ignition coils connect to the plugs too ,do I need 3 spark plug wires or 6 spark plug wires ? Please help
Old 01-04-17, 09:32 PM
firelizard
firelizard's Avatar
It's three. If you were to go out and buy new wires they would only sell you three because that's how many the car has.
Old 01-04-17, 11:47 PM
Mr Jokster
Mr Jokster's Avatar
IIRC as said above, yes 3, however when you purchase the kit, I believe it also contains new boots and retainers for the coil packs.
Old 01-04-17, 11:54 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The VVT-i 2JZ-GE engine uses a wasted spark coil-on-plug setup. 3 of the spark plugs have the coil mounted right onto them, then there are 3 wires connecting each coil to one other spark plug. So as was said, you will only need 3 plug wires.
Jeff
Bumbobee
19
09-03-20 07:43 AM
RussLS460
03-12-19 09:02 AM
James4394
IS - 1st Gen (2001-2005)
02-23-14 05:19 PM
James4394
02-11-14 01:16 PM
Redlexus07
04-13-08 11:12 AM
Quick Reply: Spark plug wires ? How many ?
