Stuck sunroof
Old 02-07-17, 04:54 PM
rvshy
rvshy's Avatar
Unhappy Stuck sunroof
Does anyone know how I can close my sunroof manually? I have a gs300 2005 and the sunroof is stuck open, it just happened randomly, the motor works i think as the roof comes out a little bit and then gets jammed , tried to look if something was Jammed but couldn't really find anything, any ideas?
Old 02-07-17, 07:46 PM
lexo98
lexo98's Avatar
When mine started sticking I sprayed some white lithium grease on the tracks and kept going back and forth until the roof moved smoothly.
Old 02-08-17, 03:56 PM
kevin3344
kevin3344's Avatar
You can put your key in the door and turn it to the lock (left) position and hold. That should close it. FYI, I had to replace my sunroof switch last summer, my sunroof would open would not close. I knew the motor was good because it would close with the key. I bought a new switch off eBay for $25.
opisdfagjo
Performance & Maintenance
10-21-18 02:24 AM
luda42688
04-22-15 11:31 AM
AimsAuto
RX - 1st Gen (1999-2003)
02-18-13 03:55 PM
RI-Lex
07-07-08 08:03 AM
kjyfkjy
10-17-04 08:57 AM
Quick Reply: Stuck sunroof
