How wide of tires can I fit on a stock 2Gen GS3
Old 02-26-17, 04:53 AM
SylvesterM
SylvesterM's Avatar
Default How wide of tires can I fit on a stock 2Gen GS3
Looking to run 18in tires just wanted to know how wide can I go without any mod? No fender rolls or anything
Old 02-26-17, 07:43 AM
Noosik
Noosik's Avatar
It also depends on the offset of the wheel...
Old 02-27-17, 07:27 AM
ZanderZ32
ZanderZ32's Avatar
This depends on so much. But what wheels do you have? Size, Width and offset? Running spacers?
Old 11-07-17, 06:56 AM
SylvesterM
SylvesterM's Avatar
Sorry for the late post but I end up going 18 and pretty much left it stock
Old 11-07-17, 07:27 PM
twsti321
twsti321's Avatar
maybe it need 1 inch lower?
Old 11-09-17, 07:11 PM
SylvesterM
SylvesterM's Avatar
I plan on going a 1.5in square.
Old 01-08-18, 02:48 PM
BayAreaLex
BayAreaLex's Avatar
Guys have gotten some really wide tires on these cars...
Widest I've seen is 305/30/19, but that was with shaved/rolled lips.
If you don't want to do that I'm sure you can get a 275/35/18 or 275/40/18 back there with the appropriate offset 18x9.5 wheels. And remember, ride height will influence this as well.
Old 01-10-18, 04:10 PM
Shadow76mm
Shadow76mm's Avatar
I’m running 275 35 20 in the rear And 20 x8.5 up front. I have 50 miles on the set up and I’m going to have to change it due to needing more beef in n the rear. I need a wheel with some radial options.
Old 01-10-18, 07:15 PM
Ilemon33
Ilemon33's Avatar
I run 275/30/19 or 19x9.5 rim rear 245/30/19 or 19x8.5 front rim with no issues. could run more. Usually can run +35 to +45 ish offset with this setup. This isnt a big setup at all, but for daily driving it rides amazing.
Jaypmanuel
02-03-19 07:03 PM
Jmonsini57
11-02-13 05:09 PM
abchoppers
05-16-12 05:25 PM
djrazr
SC- 1st Gen (1992-2000)
04-06-10 10:17 AM
oldmonk
Wheels, Tires & Brakes Forum
08-31-03 08:01 AM
Quick Reply: How wide of tires can I fit on a stock 2Gen GS3
