2004 GS430 AC not cold; no leak; compressor works
Old 04-25-17, 07:12 PM
NoviceMech
NoviceMech's Avatar
Default 2004 GS430 AC not cold; no leak; compressor works
I'm trying to trouble-shoot the cause of this problem. I've already refilled the R134; checked with UV light at night and saw no leak; the compressor works. I'm going to check the ambient air sensor. Beyond these, what could the root cause be? Should I evac the system? Thanks in advance.
Old 05-09-17, 01:00 PM
gs3tommyt
gs3tommyt's Avatar
How do you know your compressor works? It kicks on ? If you recharged the system I would hook up a/c gauges and if your high side is not 150psi then it's a weak compressor. Just replaced mine same issue clutch would engage but no cold air.
Old 05-09-17, 01:02 PM
gs3tommyt
gs3tommyt's Avatar
Also if your low side is about 80 psi it's bad it should be 30psi or so mine read high side 100psi low side 70-80psi a good compressor should be 150psi high 30psi low with a/c on. (Ambient temp when I tested was 70 degrees)
chlenz62
06-13-19 07:06 PM
pacotaco34
06-13-17 05:39 PM
ancdmd
09-08-14 03:03 PM
lbq
Performance & Maintenance
07-19-08 02:09 PM
Mark Manzo
06-16-06 06:39 PM
Quick Reply: 2004 GS430 AC not cold; no leak; compressor works
