noise coming from back right wheel
Old 06-03-03, 06:24 PM
skins990
skins990's Avatar
Default noise coming from back right wheel
a werid noise "clunking" is coming from my back right wheel and it only makes it when i dont press on the gas when i am just rolling, what in the world is causing this noise, it is prettry loud and just started making this noise a couple days ago, sounded like the tire was hitting something but it isn't, i have 20's on there, could that be the problem? i have had them on for a while, any help would be helped thanks
michael
skins990@aol.com
Old 06-05-03, 05:35 AM
///MDex
///MDex's Avatar
Let's see if I can try to help out a fellow North Carolinian.
Just when you are rolling.....
Tire out of round?
Tire hitting a suspension component?
Wheel bent?
Wheel coming loose?!
- Make sure you lugs are snug
- Check the tire for any unusual wear, and any unusual marking in the wheel well that could indicate where the contact area might be
Old 06-05-03, 03:23 PM
skins990
skins990's Avatar
lugs are on tight, the sound only occurs when i am not pressing the gas pedal, for example if i am rolling down a hill and not acc. then the noise occurs, this noise is quiet loud and i have no clue what to do, i think i might take the wheel off and see if i see anything werid? is there anything esle that anybody esle knows about this topic, i haven't driven it since this occured, i dotn want to **** anything $$$ up
thanks again
michael
uncandid
01-04-19 08:39 AM
Behemoth7
Suspension and Brakes
09-02-14 09:41 AM
Tymboo
Performance & Maintenance
12-10-07 07:20 AM
Armand
10-09-07 04:53 PM
PdPThai
11-27-06 08:09 PM
Quick Reply: noise coming from back right wheel
