1998 GS300 crank no start. Need help
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
So the car was running fine came home and car sat for an hour or so. Went to leave and it started but was idling really low then shut off after moving 5ft. Would not start again. Just cranks and wont start. Using Valet key and been using that for 2 years. Master key is lost in moving but still have the remote. Sounds like fuel pump is going when switch is on. checked EFI fuse and relay both good. Could it be the key or immobilizer? I disconnected the battery several times. It sat off for a few hours and I did the whole neg side off pumped the brakes and put it back on thing. Saw this online...lol. Still same issue. I have replaced battery, and alternator in the last year and had no issues with starting until now.
Any help is appreciated I really do not want to take it to the dealership. Towing alone will be $200+...Thanks
Sprayed starter fluid in and it almost starts...so i am guessing no fuel...hope its not fuel pump. I cannot hear it running. Whats a better way to be sure?
Disconnect the fuel line at fuel rail and ck for flowage. Sounds fuel related if fires with ether or conversely a s stated before crank sensor. Might help to have a read with Techstream to expedite the troubleshooting.
