New Motor, worth the effort?
My 98 gs400 has 300 miles on the motor and still runs strong. Sure, I get a little blue smoke at startup sometimes and I know the cams seals are starting to leak but otherwise it's a great motor.
So I know of another gs400 motor and tranny with 96k miles on it and the guy only wants $500 for it (he's pressed for cash). The car has sat for three years with a bad fuel pump.
Question: Is it worth the effort to replace my motor with a significantly lower mileage unit? I'd do the work myself. It'd be a great project for the winter.
Thanks in advance.
Thanks in advance.
Hey Jokster,
At a high level, to remove the gs400 motor is it basically?:
Remove hood (the donor car body is crap)
Unbolt engine mounts
Unbolt tranny from drive train
Detach exhaust at header / cat
Lift engine and tranny out using hooks near intake manifold
Thanks in advance
Thanks in advance
Are you sure it's your cam seals? These motors have been know to run 300,400 even 500,000 miles. If it were me I would do some investigation. It might be cheaper in the long run.
Hey Jokster,
Thanks in advance
Thanks in advance
I just think that at 293K, I'm nearing the end of this motor's easy going life. I'm sure if I pamper it, I can get another 100k out of it.
But the thought of having a cheap low mileage motor on standby is appealing.
Yea, I can see where I have a little leakage. I can see where the old/dirty oil/crud collects around of the bottom the cover. old and/or very minimal. Not enough to actually drip.
S2dannyKeo
08-17-12 09:43 AM
