Oil Pan Gasket
I did mine recently to install my turbo oil feed. It's not hard with the proper swivel socket. You need a 10mm 1/4" drive swivel like this:
https://www.amazon.com/GEARWRENCH-80256-4-Inch-Drive-Socket/dp/B001LDJD4E/ref=sr_1_2?dchild=1&keywords=10mm+1%2F4+swivel&qid=1601643615&sr=8-2
I didn't have to lift the engine or anything. You will also want a good scrapper and wire brushes with enough reach to get all the old sealant off. Also, there is no gasket, you just want to clean the heck out of both the engine side and pan and re-silicone it. One thing to consider is that I did new engine mounts last year and the engine is sitting high and proper. So if you have blown or squished mounts, you may not have the room needed.
![https://www.amazon.com/GEARWRENCH-80256-4-Inch-Drive-Socket/dp/B001LDJD4E/ref=sr_1_2?dchild=1&keywords=10mm+1%2F4+swivel&qid=1601643615&sr=8-2](https://www.clublexus.com/forums/images/misc/amazon_icon.gif)
