So the previous owner of my car managed to take apart the fuse box in the engine bay. For some reason he was not able to line up some of the clips and put it back together properly so I will be attempting to take it apart again to put it back together properly. The fuse box cover won't fit properly unless I fix this. Does anybody have detailed instructions on how to do this?
I've done this before and it is kind of a big ***** to get that outer shell from the fuse box. Undo whatever bolts you can so you can get the most maneuverability. There was some magical trick once I rammed some toothpicks or screwdrivers into it that I'm not sure how I pulled off...I think you only need to push a couple clips aside from your second pic and you can simply push it out....I'm sorry I can't say more this was two years ago when I did this.
